cutting a corner cup out
Jason Stephenson
Company Name: Marks Joinery
Post by Jason Stephenson »
HI I have a corner cupboard that is 1475 x 1475 with a back corner inset of 900 mm was just wondering if there was a way to check that the deck width is 560mm deep! and also was wondering how to nest it in to 3600mm x 1200mm sheet it nest into a 2400 x 1800 and was just wondering whether you could do this because there seems to be alot of offall
Thanks Jason
Nick M Singer
Re: cutting a corner cup out
Post by Nick M Singer »
Hi Jason. You should be able to check the deck depth in the cabinet editor using the measuring tool. You will not be able to nest a component wider than the sheet size in eCabs but if you are using a Thermwood you can rotate the components in Control Nesting and it will nest there. So probably best to use a sheet stock 2750 x 1830 or 1800 x 2400 as you said
