Problem cutting pocket
Sean O' Hare
Post by Sean O' Hare »
Hello,
I'm getting a strange result when I cut the pocket in the frame handle for this job. Anyone have any ideas?
sean
Company Name: Halls Edge Inc
Re: Problem cutting pocket
Post by Josh Rayburn »
Sean
did you forget to attach the job? or I'm just no seeing it....?
Ryan Hochgesang
Post by Ryan Hochgesang »
Sean,
I did receive your email to my Thermwood account, however the following will also be needed in addition to the CNC file you sent me:
1.) Control Nesting EXPORT file
2.) Design file from eCabinet systems (ie: .hsf, .esa, or .esj)
Thanks!
Ryan Hochgesang
Sean,
I've found that changing the Tolerance in SETTINGS, to a value of .0001 from .001 causes the correct pocket geom. to cut. The affects of tolerance change can also be monitored by zooming in on each end of the large pocket in the NESTING screen.
This scenario will be under further review here, as I know in the past the tolerance setting could potentially affect whether or not a pocket would cut, however, it wouldn’t affect the actual cut shape as seen in this case.
Thanks for the info.
Sean O' Hare
Ryan,
that works perfectly. Thanks for the prompt response.
sean
