Moderators: Mike Iubelt , Jason Susnjara , Larry Epplin , Clint Buechlein , Mike Iubelt , Jason Susnjara , Larry Epplin , Clint Buechlein
Sean O' Hare
Posts: 54 Joined: Sun, Aug 28 2005, 6:22AM
Post
by Sean O' Hare » Mon, Jan 31 2011, 12:40PM
Hello,
I'm getting a strange result when I cut the pocket in the frame handle for this job. Anyone have any ideas?
sean
Posts: 1263 Joined: Wed, Jul 01 2009, 2:19PM
Company Name: Halls Edge Inc
Post
by Josh Rayburn » Mon, Jan 31 2011, 2:44PM
Sean
did you forget to attach the job? or I'm just no seeing it....?
Post
by Ryan Hochgesang » Mon, Jan 31 2011, 3:39PM
Sean,
I did receive your email to my Thermwood account, however the following will also be needed in addition to the CNC file you sent me:
1.) Control Nesting EXPORT file
2.) Design file from eCabinet systems (ie: .hsf, .esa, or .esj)
Thanks!
Post
by Ryan Hochgesang » Tue, Feb 01 2011, 3:53PM
Sean,
I've found that changing the Tolerance in SETTINGS, to a value of .0001 from .001 causes the correct pocket geom. to cut. The affects of tolerance change can also be monitored by zooming in on each end of the large pocket in the NESTING screen.
This scenario will be under further review here, as I know in the past the tolerance setting could potentially affect whether or not a pocket would cut, however, it wouldn’t affect the actual cut shape as seen in this case.
Thanks for the info.
Sean O' Hare
Post
by Sean O' Hare » Fri, Feb 04 2011, 11:31AM
Ryan,
that works perfectly. Thanks for the prompt response.
sean
