serious issue on CN 5.62 Metric machine.
mohan kommineni
Company Name: ADP STORE FIXTURES
Country: AUSTRALIA
Post by mohan kommineni »
hi all
i have updated the 5.62 CN recently and some thing went wrong
after the update all i have done is this first job and has very bad result it does the job and all of sudden it cuts into the job before finish pass
and thought would give atry on another job nested it still same even the other job got this extra cuts on them can see them on the graph clearly iam attaching the photo
snap shot of extra cut damaged complete sheet
ControlNest5-62.cab.esj
please change the ext back to .cab
(75.96 KiB) Downloaded 512 times
AP8970_11_OPEN.twd.esj
twd file change the ext to.twd/anyway its happening same with all twd files not only this.
(212 KiB) Downloaded 504 times
will some one be able to look into this issue asap and give a quick solution to start production back asap
thanks to all
Regards
Mohan
Matt Snowball
Re: serious issue on CN 5.62 Metric machine.
Post by Matt Snowball »
Related to this problem on CN5.61 metric machine ??
Ryan Hochgesang
Post by Ryan Hochgesang »
This situation is currently under review. Can you please attach your actual design files as well? This would be .hsf, .esa, or .esj...
Thanks!
In the event an update has caused issues in your particular process, you can shut down the THM software, then run the update file again and choose the Remove option to rollback to previous version. In anycase, we need to get files associated to a particular issue in order to fix.
Thanks!
mohan kommineni
Country: AUSTRALIA
Hello Ryan
for your info sake let me put it this way its happening with every single twd irrespective of what is the design and process in it ,i have tried couple of them which were working fine before.
hope you get this if you feel still you need the file i will send it to you.
Regards
Mohan
Terry Davis
Company Name: Penn Laminates
Post by Terry Davis »
I have the same issue with CN 5.63, ruined a complete sheet of 1 1/8" board!
Terry Davis
I'm sorry we are running 5.62 and I just seen the update.....
