Profile modeler issues
Post by Forrest Chapman »
Hi All, when I run the first panel through the modeler it gives me an error on show tool path for region 1 which is the outside region. When I run the 2nd door it goes through the toolpath fine but as soon as I hit run cnc it closes the Thermwood software.
The first file is a panel saved as an assembly. The second is a mdf door. There has been an issue reported that the tool used to create the door had to have an additional inset to get all of the profile on the part. Maybe some of you might look at that as well.
Delaware.tol
(6.6 KiB) Downloaded 349 times
Deleware with new colonial test 2.zip
(424.3 KiB) Downloaded 353 times
Deleware with new colonial test.zip
(630.36 KiB) Downloaded 367 times
Daniel Vonderheide
Re: Profile modeler issues
Post by Daniel Vonderheide »
Forrest,
i will download these and look into it.
Call me Daniel if you get a fix. 864-844-1737
Daniel Vonderheide
Forrest,
If you create the tool as a symetrical tool, then apply it as the exterior tool on the mdf doors it applies crrectly. I also sent this to the profile modeler and it created the cnc code file. I have zipped up the tool, the dxf file , and a test twd file of a door.
DELEWARE SYMETRICAL.zip
(357.27 KiB) Downloaded 373 times
