Dado bug?
Company Name: Halls Edge Inc
Dado bug?
Post by Josh Rayburn »
Please see attached job file.
Take batch item 1 to CE and nest from CE.
Look at both dado operations on the left end and the right end - one of each is at .77 wide and the other is at .95 wide. I cannot explain how I even got code out of this file, but clearly something is wrong because the parts are not correct (I already ruined a couple sheets). There may be a number of errors here, software, CN....?? but I cannot figure it out.
When did the full dado operation wider than the largest tool in tooling setup automatically form a pocket cleanup operation, and why does this not happen for blind dadoes??
Export to follow shortly.
Dowling Bunk Room.zip
(1.27 MiB) Downloaded 456 times
Ryan Hochgesang
Re: Dado bug?
Post by Ryan Hochgesang »
Josh,
Do you have the EXPORT and .CNC file supporting this issue? I would like to see in order to resolve this issue.
Re: Dado bug?
Here it is. job file, twd file, export.
Please see sheets 9 and 10 when you write code with the attached export.
crane dado size 071911.zip
(1.77 MiB) Downloaded 459 times
Ryan Hochgesang
Re: Dado bug?
Josh,
I do see the oversize dado on each side panel as you mention and will keep the files under review to determine if this is a bug.
Re: Dado bug?
What can I do to cut my customer two usable parts in the meantime, do you have any suggestions?
Ryan Hochgesang
Re: Dado bug?
I would try the same design using shelves vs. TOP and DECK ..... just a thought.
