Nat Wheatley
Posts: 491 Joined: Wed, Apr 15 2009, 8:22PM
Post
by Nat Wheatley » Tue, Aug 09 2011, 6:27AM
Using the FF editor, I can't seem to adjust the size of the top or middle drawer openings of the attached cabinet. I rarely use faceframes, so I'm sure I'm missing something, just not sure what. Thanks.
Inset_Base_3_Drawer.hsf
(762.02 KiB) Downloaded 573 times
Posts: 4763 Joined: Mon, May 09 2005, 7:33PM
Post
by Kerry Fullington » Tue, Aug 09 2011, 6:52AM
Nat,
No problem here. Go to the face frame editor, click on an opening to highlight it and then enter a new height. Hit enter on your keyboard.
Nat Wheatley
Post
by Nat Wheatley » Tue, Aug 09 2011, 6:54AM
Kerry, that's what I was doing, with no luck. I'll try a reboot to see if that cures it. Thanks.
Nat Wheatley
Post
by Nat Wheatley » Tue, Aug 09 2011, 7:38AM
I was trying to adjust the opening by a very small amount and it wasn't taking (.25mm). I was able to change it fine with values larger than that.
Posts: 1263 Joined: Wed, Jul 01 2009, 2:19PM
Company Name: Halls Edge Inc
Post
by Josh Rayburn » Tue, Aug 09 2011, 7:47AM
Nat do you have "round to the nearest MM" checked in your settings?
Nat Wheatley
Post
by Nat Wheatley » Tue, Aug 09 2011, 7:56AM
Josh,
I don't. I was trying to change the opening size from 126.75mm to 127mm, and it seems odd that it wouldn't take.
Posts: 1896 Joined: Wed, May 18 2005, 7:54PM
Post
by Rick Palechuk » Tue, Aug 09 2011, 8:38AM
Nat, I got it to work by changing the size of the middle opening first to 200mm, the resized the upper one to 127mm... It is strange that it wouldn't take the .25mm change.
Terry Hall
Posts: 218 Joined: Thu, May 19 2005, 10:24AM
Post
by Terry Hall » Thu, Aug 11 2011, 6:54AM
I've run into that too Nat and only when trying to change a really small amount. I found it worked fine when I deleted the rail, then replaced it.
Nat Wheatley
Post
by Nat Wheatley » Thu, Aug 11 2011, 7:48AM
Thanks guys. I ended up doing as Rick did and it seemed to work...
