Can't Adjust Opening Size
Nat Wheatley
Post by Nat Wheatley »
Using the FF editor, I can't seem to adjust the size of the top or middle drawer openings of the attached cabinet. I rarely use faceframes, so I'm sure I'm missing something, just not sure what. Thanks.
Inset_Base_3_Drawer.hsf
(762.02 KiB) Downloaded 571 times
Re: Can't Adjust Opening Size
Nat,
No problem here. Go to the face frame editor, click on an opening to highlight it and then enter a new height. Hit enter on your keyboard.
Nat Wheatley
Kerry, that's what I was doing, with no luck. I'll try a reboot to see if that cures it. Thanks.
Nat Wheatley
I was trying to adjust the opening by a very small amount and it wasn't taking (.25mm). I was able to change it fine with values larger than that.
Company Name: Halls Edge Inc
Post by Josh Rayburn »
Nat do you have "round to the nearest MM" checked in your settings?
Nat Wheatley
Josh,
I don't. I was trying to change the opening size from 126.75mm to 127mm, and it seems odd that it wouldn't take.
Nat, I got it to work by changing the size of the middle opening first to 200mm, the resized the upper one to 127mm... It is strange that it wouldn't take the .25mm change.
Terry Hall
Post by Terry Hall »
I've run into that too Nat and only when trying to change a really small amount. I found it worked fine when I deleted the rail, then replaced it.
Nat Wheatley
Thanks guys. I ended up doing as Rick did and it seemed to work...
