Add New Hardware Dialog
Everytime I open a cabinet I seem to get this dialog. I click on the button 'Add All Hardware' each time, but when I go to save the cabinet, for some reason, a setting is not getting set saying I added all the hardware. What are the steps I need to do to keep this from coming up each time?
Rick Deskins
- Company Name: Thermwood
Re: Add New Hardware Dialog
Is it any cabinet or a certain cabinet? Can you post the cabinet? Can you also zip up and post you localstore.mdb? (C:\ProgramData\Thermwood\eCabinet Systems\localstore\LocalStore.mdb)
Rick Deskins
Rick - I don't have a \localstore subdirectory under C:\ProgramData\Thermwood\eCabinet Systems.
The problem seems to be any of the cabinets I've made that are part of my product line of RTA cabinets that I'm putting together. I attached 1 of the many cabinets in this product line. They all seem to do the same thing in bringing up that Add New Hardware dialog box.
- DB14.24.18.0.2.0.hsf
- (1.53 MiB) Downloaded 395 times
Rick Deskins
If you didnt have the localstore.mdb, none of your hardware would work. The cabinet does have a problem with it. It thinks that it has a Accuride Drawer Box Slide set on it, but does not have all the info for the slide. It has accuride as the vendor, but no model/product-code set. I will have to look more into when I get into work.
Rick Deskins
