Door desighner question
Scott Marshburn
Post by Scott Marshburn »
Is there any way to create a display door in door designer without the edge banding?
Rick Deskins
Company Name: Thermwood
Re: Door desighner question
Post by Rick Deskins »
You can create a slab door with 0 thickness edgebanding that is the same color as the sheet stock if you need to make pe cuts on the display door. If you do not need pe cuts, then you can use an mdf door.
Rick Deskins
Scott Marshburn
Thanks Rick Four reply:
But I tried that and the Attached pix and hsf file is what I get.I guess what I am asking Is would it be possible to have a selection for no edge banding just as in the edge banding editor
test door.esa
(118.02 KiB) Downloaded 492 times
test door.jpg (7.43 KiB) Viewed 8257 times
Rick Deskins
For a case like this, you should use a display panel. Then use the user part name feature to label the display panel as a door.
Rick Deskins
Re: Door designer question
Scott,
Use an MDF door created using your material of choice and then de-select any tooling under the tools tab. This will make a slab door without edge banding.
Sorry, I didn't read close enough. Rick had already suggested this.
Scott Marshburn
Thanks Rick that is what I will have to do but this method will not allow me to have the door actually on the cabinet without making it an assembly. I was hoping to avoid that by using a display door instead as all of the doors and drawer fronts for this job are made like the one I posted. Also any hardware holes will have to be placed manually .I could live with the visual deal but that does not look good for a presentation. Also how would the machine react?Maby the option to remove edg banding from display doors could be added?
Scott Marshburn
Sorry guys I posted the last before actually giving it a try the display panel method will work without saving as an assembly but I will still have to apply any hardware holes manually
