Moderators: Mike Iubelt , Jason Susnjara , Larry Epplin , Clint Buechlein , Mike Iubelt , Jason Susnjara , Larry Epplin , Clint Buechlein
Scott Marshburn
Posts: 867 Joined: Sat, Mar 05 2011, 7:29AM
Post
by Scott Marshburn » Fri, Apr 27 2012, 5:49AM
Our Fly Cutter got bent and we need a new one but the fly cut program that came with the machine is set up with our current 1.75 dia. tool. I searched the online store but cant seem to find a tool with that dia.Can the code be edited so we can use a different dia. tool?
Scott Marshburn
Post
by Scott Marshburn » Fri, Apr 27 2012, 6:00AM
Ok I opened the program in note pad it seams that all I have to do is set up the 999 tool to the new tool in tool management. Am I correct on this?
Will Williamson
Posts: 455 Joined: Thu, Dec 08 2005, 6:10PM
Post
by Will Williamson » Fri, Apr 27 2012, 7:06AM
Thats because you were looking for the wrong Dia. The correct Dia is 50mm or 1.9685. That is the max Dia that will fit into your tool holder. 50mm Lietz is the replacement tool. That is what my CS45 uses
Will
http://www.willmade.com
Scott G Vaal
Posts: 1740 Joined: Tue, May 17 2005, 12:44PM
Post
by Scott G Vaal » Fri, Apr 27 2012, 7:49AM
Scott Marshburn wrote: Our Fly Cutter got bent and we need a new one but the fly cut program that came with the machine is set up with our current 1.75 dia. tool. I searched the online store but cant seem to find a tool with that dia.Can the code be edited so we can use a different dia. tool?
Scott,
You can get the tool via Thermwood. Here is a link to the tool we recommend:
http://www.woodworkerswholesale.com/Ins ... l178-2.htm
Also, Yes, all you need to do is set up the correct diameter for tool number 999.
Scott Marshburn
Post
by Scott Marshburn » Fri, Apr 27 2012, 5:54PM
Thanks Scott I guess that means we can use our 1/8 end mill in the mean time
Scott G Vaal
Post
by Scott G Vaal » Mon, Apr 30 2012, 8:26AM
Scott Marshburn wrote: Thanks Scott I guess that means we can use our 1/8 end mill in the mean time
LOL... Yep, but it might take you till Thursday to get done.
