help setting up new fly cut tool
- Scott Marshburn
Our Fly Cutter got bent and we need a new one but the fly cut program that came with the machine is set up with our current 1.75 dia. tool. I searched the online store but cant seem to find a tool with that dia.Can the code be edited so we can use a different dia. tool?
- Scott Marshburn
Re: help setting up new fly cut tool
Ok I opened the program in note pad it seams that all I have to do is set up the 999 tool to the new tool in tool management. Am I correct on this?
Will Williamson
Thats because you were looking for the wrong Dia. The correct Dia is 50mm or 1.9685. That is the max Dia that will fit into your tool holder. 50mm Lietz is the replacement tool. That is what my CS45 uses
Will
http://www.willmade.com
- Scott G Vaal
Scott,Scott Marshburn wrote:Our Fly Cutter got bent and we need a new one but the fly cut program that came with the machine is set up with our current 1.75 dia. tool. I searched the online store but cant seem to find a tool with that dia.Can the code be edited so we can use a different dia. tool?
You can get the tool via Thermwood. Here is a link to the tool we recommend: http://www.woodworkerswholesale.com/Ins ... l178-2.htm
Also, Yes, all you need to do is set up the correct diameter for tool number 999.
- Scott Marshburn
Thanks Scott I guess that means we can use our 1/8 end mill in the mean time
- Scott G Vaal
LOL... Yep, but it might take you till Thursday to get done.Scott Marshburn wrote:Thanks Scott I guess that means we can use our 1/8 end mill in the mean time
