Drawer adjuster constraints question?
Terry Davis
Company Name: Penn Laminates
Post by Terry Davis »
After updating to the latest version of ecabs it will no longer update the constraints I make after returning to the main screen. I noticed this when I do Blum head adjusters and handle holes in the part editor, they move into their proper position when constrained but it is not reflected when returning to the main screen they just stay in the pre-constrained positions. This however has no effect when machining everything comes out right.
Scott G Vaal
Re: Drawer adjuster constraints question?
Post by Scott G Vaal »
Terry Davis wrote:After updating to the latest version of ecabs it will no longer update the constraints I make after returning to the main screen. I noticed this when I do Blum head adjusters and handle holes in the part editor, they move into their proper position when constrained but it is not reflected when returning to the main screen they just stay in the pre-constrained positions. This however has no effect when machining everything comes out right.
Terry,
I cannot seem to reproduce this, but I am not sure I am doing exactly what you are. Please attach a cabinet or job that demonstrates this issue and some steps to take to reproduce it. I will see if I can get it to happen for me.
Terry Davis
OK I will post the job, just take one of the drawer heads into the constraints manager, make a change, and see if it updates when returning to the main screen.
Terry Davis
Not sure if I did this right but here is the files.
New Building.esa
(6.06 MiB) Downloaded 893 times
New Building.jpg (7.41 KiB) Viewed 9587 times
Scott G Vaal
Terry,
I see what you are talking about now and will get it added to the list to be fixed. If you regenerate the cabinet, the holes will then display correctly (Construction settings, then select OK). As you said, it will still nest and CNC correctly but not graphically till a regen. Sorry for the inconvenience.
Terry Davis
Great, thank you!
