Moderators: Mike Iubelt , Jason Susnjara , Larry Epplin , Clint Buechlein , Mike Iubelt , Jason Susnjara , Larry Epplin , Clint Buechlein
Scott Marshburn
Posts: 867 Joined: Sat, Mar 05 2011, 7:29AM
Post
by Scott Marshburn » Sat, Jun 22 2019, 6:07PM
I don't know if this is even possible or not. Has anyone tried cutting sliding dovetails?
Will Williamson
Posts: 455 Joined: Thu, Dec 08 2005, 6:10PM
Post
by Will Williamson » Mon, Jun 24 2019, 1:20PM
Yes, we have, cut sliding dove tails, into solid wood counter tops, to hold flat.
Will
http://www.willmade.com
Scott Marshburn
Post
by Scott Marshburn » Mon, Jun 24 2019, 8:06PM
Thanks, Will. Could you share the prosses that you use?
Will Williamson
Post
by Will Williamson » Tue, Jun 25 2019, 5:59AM
I milled a pocket 3/4 deep, then inlined with a dovetail tool, I drew the dovetail tool. to determine my offsets. i started the cut off the material and then cut the, two long sides and the end. then I took some flat stock and outlined it. there again using my cross section to determine the offset.
I use Aspire for all my custom millwork
Will
