Is anyone else using applied ends and having troubles deleting them?
In the attached cabinet, I cant delete the right panel.
Its a little bit intermittent.The left end applied end also plays up for me as well, but in this example it deletes.
Std Base Frameless.jpg (14.48 KiB) Viewed 14661 times
Mark,
I installed the latest version of Ecabinets just now and tried the applied ends feature on your cabinet. I had no issue deleting the applied end that you had installed. You might have a gremlin
Thanks Guys
Hi Ralph,
No Gremlins (only the one in my brain)
Ian surmised it correctly.
I have used the applied end feature quiet a bit and its great for setting up kitchens in custom layout.
I hadn't used it myself for about 6 months and forgot the selection methods.
Thanks for the help
