backpocket not cutting
Jacob Janzen
Company Name: California Closets
Post by Jacob Janzen »
We use dxf files from our design tools to generate our parts and a parts list.
Our problem is that when we define a backpocket, thermwood isn't picking it up or cutting it. I have checked the files against a regular pocket layer and all appears the same except for changing pocket z11p0 to backpocket z8p0 (19mm material) and the geometry in the LWPOLYLINE is set to cut from the bottom.
All the codes in the dxf are otherwise identical.
pocket:
Code: Select all
  0
LWPOLYLINE
  5
51
  8
pocket z11p0
 62
0
370
0
 48
1.0
  6
BYLAYER
100
AcDbEntity
100
AcDbPolyline
 90
4
 70
1
 38
0.0
 39
-10.0
210
0.0
220
0.0
230
1.0
 62
1
 10
20.0
 20
-8.0
 30
0.0
 10
85.0
 20
-8.0
 30
0.0
 10
85.0
 20
10.0
 30
-10.0
 10
20.0
 20
10.0
 30
-10.0
backpocket:
Code: Select all
  0
LWPOLYLINE
  5
51
  8
backpocket z8p0
 62
0
370
0
 48
1.0
  6
BYLAYER
100
AcDbEntity
100
AcDbPolyline
 90
4
 70
1
 38
-19.3
 39
11.0
210
0.0
220
0.0
230
0.0
 62
1
 10
20.0
 20
-8.0
 30
19.3
 10
85.0
 20
-8.0
 30
19.3
 10
85.0
 20
10.0
 30
29.3
 10
20.0
 20
10.0
 30
29.3
The files look good in IntelliCAD so I'm really at a loss here.
Any ideas what's going wrong?
Jeremy Schiffer
Re: backpocket not cutting
Post by Jeremy Schiffer »
I'd start by specifying a tool / tool diameter. Since Thermwood introduced the ability to call a tool by name instead of diameter, that's how we've done it.
For instance:
the old way: pocket d9p5 z8p0
the new way: pocket z8p0 [3185]
Either way, a tool is specified. Your code isn't specifying one, so I'd try that first.
CS-41 4x8
CS-45 5x12
Jacob Janzen
Jeremy Schiffer wrote:I'd start by specifying a tool / tool diameter. Since Thermwood introduced the ability to call a tool by name instead of diameter, that's how we've done it.
For instance:
I've never specified anything other than pocket zXXpX, drill zXXpX, etc.
What is the nomenclature you're referring to? I don't see anything about it in the dxf reference.
Thanks!
Jeremy Schiffer
Page 96 of the Control Nesting manual has that info.
CS-41 4x8
CS-45 5x12
Clint Buechlein
Company Name: Thermwood Corp
Post by Clint Buechlein »
Jacob Janzen wrote:We use dxf files from our design tools to generate our parts and a parts list.
Jacob,
Can you post the DXFs and an export from Control Nesting? If you can't post them you can upload them here http://info.thermwood.com/thermwood-file-upload-page, just make sure to put Attn Clint in it.
Jacob Janzen
Clint,
How do I export from Control Nesting?
Jacob
Clint Buechlein
Jacob Janzen wrote:Clint,
Jacob
Jacob,
When in Control Nesting, choose File and then Export. Choose the location you want to save the file.
Jacob Janzen
Clint,
I got the export and wrapped it with my partslist.csv & dxf files.
Here's the link: https://1drv.ms/u/s!Am4RwQL4goIL1cgn0M2 ... w?e=nQ5ns6
Jacob
Clint Buechlein
Jacob,
Files downloaded. I'll dig into them and let you know.
Clint Buechlein
Jacob,
As far as I can tell it is working as I would expect it to.
Part of the disconnect may be an understanding of how Control Nesting handles operations. With DXFs, singled sided material isn't an option. If the material isn't defined as single sided for any file type Control Nesting looks at which side of the material has the most amount of operations and that becomes the top of the material. So in your flip DXF with the pocket, the pocket and drills that are labeled as back operations outnumber the other operations. That makes the other operations backside operations, while the ones you defined as "back" are now front operations. The code that is output looks like depths are adjusting correctly for the reorientation of operations.
I believe I'm on the same path, but if I'm way out in left field let me know and I'll look towards other issues.
Jacob Janzen
Clint,
It wasn't showing the pocket on the backside operation on the Nest Overview... Was it in fact going to cut the backpocket? It didn't look like it was going to on the display.
I'll take another look at it.
Jacob
Clint Buechlein
Jacob
Jacob,
Ignore my previous reply, I was in left field (or somewhere left of that). I see what you are saying about it missing. I suspect it is an issue in how the software is creating the DXF. If I load your DXF into Mastercam, and just resave it, it shows the pocket in the nest and creates the code to cut. Mastercam is likely repairing the DXF in some fashion. You can look to see if there is an AutoCAD output version when saving the DXFs. Usually saving in the AutoCAD version 2004-2006 has worked well for other customers in different softwares.
Jacob Janzen
Clint,
Thanks I'm going to try tomorrow I was doing some geometry changes because it didn't work before but maybe we've run an update where my "fix" has now broken things. You just reminded me of flipping geometries around that I'd forgotten about so I'll try reverting that and seeing if it works.
I'll report back tomorrow.
Jacob
Jacob Janzen
Clint,
Thanks! I fixed the geometries back to original and it worked great!
Jacob
Clint Buechlein
Jacob
Jacob,
Good deal, glad you were able to get it fixed.
