How to get the screw holes for through-fastening between lock tenons?
Gene Davis
Company Name: Gene Davis Builder
Post by Gene Davis »
I can generate pocket holes between lock tenons, but how to do those for through-screws. See the pic from a cab I got from a production share shop.
Is this all manually done and then set up for seed cab sizing using constraints? Seems tedious if that is the only way.
Scott Marshburn
Re: How to get the screw holes for through-fastening between lock tenons?
Post by Scott Marshburn »
I have a kD hole pattern that I use for this. I modified an existing kd pattern by removing the cam hole and changing the pinhole to the depth and diamenter for the through-hole.
Scott Marshburn
here is the pattern file that I use for .75 materials
p75matpilothole.zip
(1.56 KiB) Downloaded 1044 times
http://www.thermwood.com/forums/downloa ... w&id=16960
