Gene Davis
Posts: 70 Joined: Sat, Sep 02 2017, 7:30PM
Company Name: Gene Davis Builder
Post
by Gene Davis » Mon, Aug 16 2021, 6:55PM
I can generate pocket holes between lock tenons, but how to do those for through-screws. See the pic from a cab I got from a production share shop.
Is this all manually done and then set up for seed cab sizing using constraints? Seems tedious if that is the only way.
Scott Marshburn
Posts: 867 Joined: Sat, Mar 05 2011, 7:29AM
Post
by Scott Marshburn » Mon, Aug 16 2021, 7:48PM
I have a kD hole pattern that I use for this. I modified an existing kd pattern by removing the cam hole and changing the pinhole to the depth and diamenter for the through-hole.
Scott Marshburn
Post
by Scott Marshburn » Mon, Aug 16 2021, 8:14PM
