KD/RTA Change Default
Ingbert Kilian
Company Name: Loeven Morcel
Post by Ingbert Kilian »
Hi
I have a question. Is it possible to change in eCabinets the Default Hardware and Hole Pattern in KD/RTA construction?
Please see attached Picture, highlighted
Thank you
Stuart Douglas
Re: KD/RTA Change Default
Post by Stuart Douglas »
Lol "Sub'ed"
I haven't been able to do this yet, and I know of no-one who has. I can't even get the construction settings to hold a DIFFERENT hardware ptn for joinery, I literally have to insert a part, then change the hardware pattern EVERY. DARN. TIME. :wall:
_____________
NVME SSM2HD 1TB NTFS
I haven"t been able to do it from there.
I use the main window and the KDA Rtas as in the attached picture to change the default.
It sticks even when you save it.
You can change all the fittings or patterns for a directory in global modifications.
Always make a backup so if something goes wrong, nothing is lost.
The previous advise is subject to the caveat "all care , no responsibility" :joker:
Hope that helps
Ingbert Kilian
Yes it is working!
Thank you!
