error with new update
JR Allen
Company Name: JRs Woodworx
Post by JR Allen »
I've never had this happen with other updates, any info would be helpful. Thanks
Stuart Douglas
Re: error with new update
Post by Stuart Douglas »
Also, The update page on the thermwood site is still showing the old date and the download file is the old file as well? Not sure where even to get the new update otherwise. :?
_____________
NVME SSM2HD 1TB NTFS
Clint Buechlein
Company Name: Thermwood Corp
Post by Clint Buechlein »
JR Allen wrote:I've never had this happen with other updates, any info would be helpful. Thanks
Try redownloading the installer, in the event the download was corrupted. Also make sure to right click and Run as Administrator on the downloaded file just to make sure it isn't permission related.
Stuart Douglas wrote:Also, The update page on the thermwood site is still showing the old date and the download file is the old file as well? Not sure where even to get the new update otherwise. :?
As far as we can see and others have reported the update is good and live. Make sure when you go to the update page to refresh it in the event your browser is storing the old page in cache. If you are using Chrome you can press CTRL+F5 to force a refresh.
JR Allen
Post by JR Allen »
Got it to install from the site, thanks for the help
Stuart Douglas
That was the solution! Thanks!
_____________
Sarah Jeffries
Company Name: Millmade Inc
Post by Sarah Jeffries »
After downloading and then running as administer I'm getting a window that says "Windows cannot access the specified device, path, or file. You may not have the appropriate permissions to access the item.
Clint Buechlein
Sarah Jeffries wrote:After downloading and then running as administer I'm getting a window that says "Windows cannot access the specified device, path, or file. You may not have the appropriate permissions to access the item.
Sarah,
Do you have eCabinets User Data Path set to a network location? If so you need to run the registry edit on the eCabinets download page.
