GLITCH in part editor for doors that are edged
Nicholas Kiss
Company Name: Clearcut
Post by Nicholas Kiss »
hey I've been struggling with these part edited doors and drawers that have certain patterns which need to be constrained and it seems i part edit from the design tab then door/drawer editor, then go to constraint manager there is a slit cut off of my door, which i then have to go to part editor to delete it
this is very frustrating because it seems like that also causes minor bugs like constraint manager constraints lose a reference point and sometimes deletes the part edit cuts entirely, this is also happening when i part edit a door from the cabinet editor but i'll be showing pictures from the design tab- door/drawer editor down below
i attached a step by step picture of when the problem occurs see attachments
once i delete the part edit (refer to step3.png) then i continue constraining and thats when interesting.png happens, where it seems offset by a mm
also the circled part is me wondering if maybe door edging is causing this problem? it looks like it overlaps from the y axis grid line seems like its shifted to the left of it by something like a millimeter
Re: GLITCH in part editor for doors that are edged
Hi Nicholas.
Perhaps if you post the cabinet we can understand better.
I cant fully follow your process or method thinking.
What is the slit?
Mark
Nicholas Kiss
Hi Mark, the slit isn't something that i added, it randomly appeared so i don't know what it is, just that i have to get rid of it
the pictures are from the first part editor picture bottom to top they indicate exactly what i do to make the handle holes that i placed which you can see in the constraint manager
the steps were, part edit and cut out using geometric shapes (1/8 diam circles)
constrain holes to proper size and location
go back to main which in this case is door/drawer editor (while part editing doors with edges i always have this problem)
then when i go back to part editor the slit randomly appears and constraints are lost
you can recreate this problem by adding a slab door with edges from the design tab at the top and making these 2 holes and constraining the holes properly
i'll add my door hsf file
Nicholas Kiss
White Door euro handle.jpg (2.52 KiB) Viewed 12999 times
white door euro handle.hsf
(172.02 KiB) Downloaded 877 times
Hi Nicholas.
When I examined it in the part editor it seemed okay. When I zoom in I cant see that slit. (it does look like edging in your image)
The door came into my ecabs unconstrained.
Unless somebody else comes in with an answer, My two cents.
I used to have a lot of problems with constraints. I still do sometimes, but cleaning up how I constrained solved a lot of problems.
So see that zero constraint, I think that is where you tried to tie the two holes onto the same dimension, From my experience the back end tries to join or put those holes together and tends to then drop the constraint or something. I was once told by Scott Val (a previous mod like Clint) That ecabs doesent actually like two points in exactly the same spot, I think it needs to track where every point is and when two points are in the exact same spot on the same layer it gets a headache differentiating the points so tries to fit them together.
If I was constraining that configuration I would constrain each hole separately.
I have attached your door constrained how I would do it.
I have also found formulas can save a lot of time like, the W/2-(half of handle or half distance apart width) will resize with the door.
I notice that the holes don't go all the way through, If they are supposed to go all the way through I would do that in the part editor, also when you add them in the part editor just type in the diameter. Then the diameter and depth stick to the hole without the need to constrain.
Might not be much help but something to think about. :)
white door euro revised.hsf
(172.02 KiB) Downloaded 798 times
Nicholas Kiss
[quote="Mark McCallum"]
thanks Mark, i like the way you formulate your constraints; the holes are supposed to not go through all the way
i tried to recreate the door again and this time the problem is in a much higher caliber, I'll link the doors again and if it looks right in part editor then try hitting the eraser and it'll show just how messed up it is, hopefully someone can look at this
White door Euro Handle.jpg (3.8 KiB) Viewed 12848 times
(1.31 MiB) Downloaded 851 times
Messed up door.jpg (2.99 KiB) Viewed 12848 times
messed up door.hsf
(1.11 MiB) Downloaded 924 times
Hi Nick
I'm not sure whats going on there.
I am putting the door into the doors, saved, slab file
I just use the software, so I like you am just trying to reproduce your steps.
I couldn't load your door as it was broken and I have attached the error messages.
It still looks like a Constraints thing to me, Maybe there is a constraint that has gone invisible.
As a side point, I have a lot of weird stuff happen as well, but to track it down, is sometimes darn near impossible and unless I can reproduce it I just go back and redo it, and 9 times out of ten it works.
But don't let that deter you, I cant get this one but, If you can document and reproduce a glitch definitely report it, it helps us all. :beer:
Also, we other users may have not bothered to follow "that something weird happened once" but when someone else reports it, it jogs a thought and we can help track it.
Its sometimes that little unthought of mouse click or random setting on your setup that alerts or sets off the problem.
The Therwood programmers are the best and fix them when they can.
As Clint often says try and take a standard slab door or cabinet and reproduce it from there. (I hate it when he says that, :joker: but he is right)
Also, I still wasn't clear where you are part editing from so I attached an image of how I think you are
doing it.
I also started a new door with edging on it and part editor cuts. seems to work for me.
Sorry I couldn't be more help :(
16.2 colourboard test.hsf
(94.02 KiB) Downloaded 853 times
Hi Nick.
Hmmm
There could be something funny there. If there is its typically ghostly. :? :D
Nicholas Kiss
Mark McCallum wrote:Hi Nicholas.
Thanks mark! We figured it out, the doors i was using was initially created on an older version
so i went ahead and did clints old trick and it worked! Recreating the door should have been the first thing i tried; the files i was using was corrupt constraints wise
If anyone else has problems with doors and constraints definitely try recreating the door from the standard folder
thanks everyone for your help!
