Nesting error
Chris Say
Nesting error
Post by Chris Say »
I loaded a job with part editor cuts and display panels and as soon as I click ok I get an error saying \"Data type conversion error\". What does this mean and what do I need to do to fix it? Here is the file if it helps.
Jason Susnjara
Post by Jason Susnjara »
Chris,
Are you getting this error in eCabinets or Control Nesting at the machine?
thanks,
Chris Say
Post by Chris Say »
I am getting this error at the machine. I got a will not nest this part error in ecabinets for the left-right stretcher. When filtered, it nested correctly. I made it in build 9. I regenerated it in build 10 and resaved it and get the same error at the machine. Now when I nest it in ecabinets it shows the nest for a brief second then the nest diagrams disappear.
Jason Susnjara
Hi Chris,
I just emailed you two files and they seem to work now. Try them and let me know how they worked.
thanks,
PlatinumDave
Company Name: Platinum Kitchens
Re: Nesting error
Post by PlatinumDave »
Hey Gentleman. I am getting the same error today for the first time on our CS45 Machine. Any words of advice to resolve this?
Dave
Dave Snowdon
Platinum Kitchens
Summerside, Prince Edward Island
Canada
platinumkitchensdave@gmail.com
Platinum Kitchens Facebook Page
PlatinumDave
Re: Nesting error
Quick update.
As I try to nest now it just simply hangs and then after 30 minutes crashes thermwood all together.
Dave Snowdon
Platinum Kitchens
Canada
Jeremy Schiffer
Re: Nesting error
Post by Jeremy Schiffer »
Are you able to nest any other jobs? Is it just doing it with one particular job?
CS-41 4x8
CS-45 5x12
PlatinumDave
Re: Nesting error
Hey Jeremey, thanks for reaching out! It is only this one job that gives that error. I have never seen it before. And am cutting another job today that nested perfectly, wrote and is cutting now.
Dave Snowdon
Platinum Kitchens
Canada
Jeremy Schiffer
Re: Nesting error
Sounds like probably some part editor cut disagreeing with things. I would start by removing any cabinets with part editor cuts or any other "weirdness", and work thru by the process of elimination until it nests successfully.
Unfortunately the forum has reverted back to Molasses Mode, so it has taken me like 10 minutes to get this far... good luck with it!
CS-41 4x8
CS-45 5x12
