Need help drawing
Rob Davis
Need help drawing
Post by Rob Davis »
I am attaching (hopefully) a sketch of what I need to draw. Angled storage under a staircase with cropped doors, etc. I can't figure out an easy way to do this other than build separate cabinets and using part editor, changing each side, back and door to get the angle I need. Is there an easy way to angle the top of a cabinet and get the doors to follow, etc? Could I make a 96" wide cabient with multiple doors?
I know some of you will just do this in seconds but I want to know HOW to do it as much as I want to have it done.
Thanks for your help.
Rob
Stair storage.pdf
(5.27 MiB) Downloaded 342 times
Re: Need help drawing
You can make a single cabinet then modify the back in the Part Editor. You will have to make the doors in the Part Editor also and the top will be a Display Panel of the appropriate size, rotated to the correct angle.
The good news is that you can use top offsets for the left end and any partitions.
