Face Frames for corner base cabinets
MarkWellscc
Post by MarkWellscc »
I am designing a corner base cabinet that has 3 banks of drawers. The center bank of drawers will be long "corner" drawers. I can't figure out how to
add another "middle stile". Actually, I need "2" middle stiles. When I go to the faceframe editor there is not an option to "add a middle stile" as there is
to add middle rails. Is this not possible with this version or am I missing something?
Thank you in advance,
Mark Wells
MWellsCC@aol.com
Re: Face Frames for corner base cabinets
I am not sure what you are looking for
Test Corner Cab 12-2-09_3.jpg (66.6 KiB) Viewed 5290 times
Test Corner Cab 12-2-09_5.jpg (67.48 KiB) Viewed 5290 times
Test Corner Cab 12-2-09_4.jpg (79.35 KiB) Viewed 5290 times
Dennis Englert
Post by Dennis Englert »
The corner cabinet does not have a mid-stile option.
You'll need to either install a display board or display panel as a mid-stile. Make sure that you associate the added component(s) to the cabinet. When you install the doors, you'll need to adjust the reveals or overlays to compensate for the mid-stiles. In the example of three doors, the middle door is most likely installed as a display door and must be associated with the cabinet. Display boards, panels and doors will be listed in the appropriate lists, i.e., cut, cost, and buy lists.
Dennis
Paul Amos
Company Name: Fretworks
Post by Paul Amos »
Mark,
Why complicate things ?
Your method will still need dividers for the drawer runners and lots of 45degree cuts, you will probable need to assemble it on site unless you have wide access.
Can you not make 3 standard base cabinets 1 deep 2 shallow with the drawers in.
Paul
