Part editor crash
Bryan J Tanner
Company Name: Decor Designz
Part editor crash
Post by Bryan J Tanner »
Hi the part editor keeps crashing on me with the following error report.
Problem signature:
Problem Event Name: APPCRASH
Application Name: ECABINETS.exe
Application Version: 6.0.31.0
Application Timestamp: 4b4b3425
Fault Module Name: StackHash_5e3f
Fault Module Version: 6.1.7600.16385
Fault Module Timestamp: 4a5bdadb
Exception Code: c0000374
Exception Offset: 000c283b
OS Version: 6.1.7600.2.0.0.768.3
Locale ID: 5129
Additional Information 1: 5e3f
Additional Information 2: 5e3f10ed0a3ba4d7957eefd9b5625f28
Additional Information 3: e4de
Additional Information 4: e4dee140d87800817ba7778422897759
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid= ... cid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
Any help on how to avoid this?
HP Pavilion DV6
NVIDIA GeForce GT 230M
Windows 7 Home Premium
Rick Deskins
Company Name: Thermwood
Re: Part editor crash
Post by Rick Deskins »
do you have some steps to reproduce this?
Rick
Rick Deskins
Post by Forrest Chapman »
I also noticed a lot of crashes recently. This is what I narrowed my problem to. If you have a cabinet that you apply an display panel to and then associate it you will have problems with doing part edits. I had crashes when trying to remove the edits and reapply. I took the part into PE and removed the profile cut and geometry cut and then tried to make other geo cuts and when I went to apply the profile it would lock up and crash. Happened over and over again until I remove the association to cabinet.
Hope this helps,
Ryan Callahan
Post by Ryan Callahan »
Forrest,
This helps us look towards a more specific area for the problem, but so far, I am not seeing it. Can you post a simple cabinet for me to look at? This will help me focus more on the trouble area.
Be sure to list steps once to make the cabinet show the errors.
Ryan Callahan
Thermwood
Bryan J Tanner
Ryan
I created a display cube 980mm x 480mm x 170mm
Take this to the part editor
Go to the contour screen load the SC980 parasolid file
select all
Translate this from -440,-140 to 0,0 (note one contour doesn't translate)
Don't delete any elements this will cause a crash!
Return to the part editor
cut pocket the smaller circles straight through
cut pocket the larger circles to 168mm
cut pocket the larger and smaller bowls to 166mm
cut pocket the elements that would normally raise up in the drainer 5mm ( it achieves the look)
cut pocket the smaller outline 2mm
radius the corners 17mm
look at the back
remove with rectangles and geometry cut pocket excess cube
exit part editor.
Crash! :lol: :wall:
SC980 parasolid.zip
(46.29 KiB) Downloaded 353 times
HP Pavilion DV6
Ryan Callahan
Bryan,
Thanks for the steps and the file. Right now, I am thinking that the problem is in the parasolids file. When I open the file in a viewer, there are some strange lines that probably do not belong, as well as hidden lines. I have put an issue in to see what can be done, and at least set a catch in the program to prevent the crash. Once you can load the x_t file in the Contour mode and delete a line, I think the other parts of the issue may correct themselves.
As I learn more, I will post.
Ryan Callahan
Thermwood
Bryan J Tanner
Ryan
Here is the DXF file I started with.
I deleted the elements I didn't need and then saved it.
Hope this helps
Bryan
kingr15.zip
(11.5 KiB) Downloaded 350 times
HP Pavilion DV6
