Slab Cabinet doors
Nick Rizzo
Company Name: Rizzos Cabinets
Slab Cabinet doors
Post by Nick Rizzo »
Is there a trick to adding slab doors that you can build in house like in version 5. I don't have the option in the door designer. I have the option for all other doors but slab
JohnLashuay
Re: Slab Cabinet doors
Post by JohnLashuay »
Nick,
Have you tried taking your cabinet into the Door/ Drawer Editor?
Once in the D/DE
1.click the Door/Drawer Selection button then
2. under select source: Conestoga > Standard
3. scroll down to the MDF Standard Door
There is an option to the right of the door when it is selected to "Build in House"
Hope this helps!
-John
http://www.rylexonline.com
Thermwood CS 43
Rick Deskins
Company Name: Thermwood
Post by Rick Deskins »
The build in house option for slab doors will be included in the next update.
Rick Deskins
Nick Rizzo
do you have any idea when the next update will be? I am working on a large commerical project that has 3/4" hard rock maple door with 3mill pvc edges that have to be cabinet matched.
Nick
Nat Wheatley
Post by Nat Wheatley »
Nick,
Would it work for you to add an existing 3mm slab door/drawer front to the library, and when you call them up in the Door/Drawer Editor, change the banding and door material to ones with the textures that you needed? Here are my generic 3mm door and drawer front, that imported from V5 with my other items, and seem to work fine.
Nat
Slab_DF_3mm PVC.hsf
(14.02 KiB) Downloaded 353 times
Slab Laminate_3mm PVC.hsf
(14.02 KiB) Downloaded 334 times
