Line Drawing Editor issues
Tony Marrazzo
Post by Tony Marrazzo »
I haven't been on this forum for quite a while, had a hard time remembering what my username and password was! Anyway, I drew up a kitchen and while trying to take walls to the line drawing editor 2 of the 3 went in reversed, with the back side of the wall showing. All of the walls are drawn the proper direction, and only one will show the cabs. any ideas???? :wall:
Tom Nienow
Company Name: Nienow Woodwork
Re: Line Drawing Editor issues
Post by Tom Nienow »
I came across the same problem, also cabinets would be shown inside out and with parts (stiles, rails, doors) missing or in the wrong places. Have to make a pdf and print that, and that isn't always the best format, uses more ink on my computer.
Tony Marrazzo
I can't even do that, all I see is the back side of the wall in the line drawing. If I highlight the entire wall, I can click on the command to number the cabinets, and the numbers will show on the back side of the wall but I can't see any of the cabinets, and there is no way to reverse the view or the wall. I am sure it is something simple, I just don't know what. I am seeing several things that don't seem to work right with the new version, I want the old one back.......
Tony,
This was an issue during Beta Testing of V6 but I don't see it in the release of Version 6. Post your job so they can take a look at it.
Is this a job created in V6 or brought forward from V5.2?
Lamar Horton
Post by Lamar Horton »
I have had a wall or two do that and I was able to select the wall and use the rotate feature to spin it around.
Tony Marrazzo
Kerry Fullington wrote:Tony,
It was created in Version 6. I will try to post it. Thanks!
Tony Marrazzo
Tried it again this morning and I was able to rotate the wall 180 in the line editor and the cabs were there. Thanks guys!
Ryan Callahan
Post by Ryan Callahan »
Tony,
I was curious if you could still post a sample job showing this behavior. I just want to make sure it gets corrected if there is a problem.
Thanks.
Ryan Callahan
Thermwood
Tony Marrazzo
Ryan Callahan wrote:Tony,
Thanks.
Here you go, I had to delete 2 walls of cabinets to make the file small enough to send - but if you try to take the remaining cabinet wall into the line editor it will go in backwards. Thanks!
Tony
Thermwood Test.esj
(3.16 MiB) Downloaded 1318 times
Ryan Callahan
Tony,
Seems what is going on is you have used Reverse Build Direction on the wall. You can see this by creating a simple wall, select Wall Options->Reverse Build Direction, place a cabinet on the front side of the wall, then take to LDE. It will come in backwards as you described.
So this is an issue to be addressed.
Thanks for posting your job so that I could see exactly what is going on.
Ryan Callahan
Thermwood
Mike Snodgrass
Post by Mike Snodgrass »
I have been having this happen since before version 6. It seems to have have slacked off lately though.
Tony Marrazzo
I was trying to remember if I had to reverse any walls, and after thinking on it a while I remembered I did, but only the one with the cabs on the wall. It happens on two of the 3 walls, the one in the drawing that has cabinets still on it (the one I reversed direction) and the wall with the door in it (that one was never reversed). I had to remove the cabs on two of the walls to make the file small enough to send. Thanks again!
Tony
Company Name: Halls Edge Inc
Post by Josh Rayburn »
Same here.
Here's the job:
closet.zip
(6.03 MiB) Downloaded 1359 times
The walls on the left went into the LDE as expected
The walls on the right were all reversed.
There was no 'reverse build direction' used to create the walls in this job
Ryan Callahan
Josh,
Thanks for the job. This error is fixed for the next release. I was able to take every wall into the LDE and they all came in as expected.
Tony, thanks for showing this to us.
Ryan Callahan
Thermwood
Tony Marrazzo
No problem, glad it is fixed - keep up the good work!!!
Tony
