Hi guys
So, I installed build 2 (thanks for all the fixes!! 43 I count, good speed getting it out!)
But, hardware Database has got lost again.
Any ideas?
Hardware DB
Bryan J Tanner
- Company Name: Decor Designz
Hardware DB
HP Pavilion DV6
NVIDIA GeForce GT 230M
Windows 7 Home Premium
- Josh Rayburn
Re: Hardware DB
Which OS are you running?
Check in the localstore/backup directory for the latest backup file of localstore.x.x.x.mdb and make a copy of it.
Then rename the copy 'localstore.mdb' and place it in the localstore directory, replacing the current (empty) localstore.mdb file
you should be good to go
Actually I would recommend saving that current localstore.mdb file just in case though.....hope that helps
Bryan J Tanner
Re: Hardware DB
I'm running windows 7 home premium
Where do I find this?Josh Rayburn wrote:Check in the localstore/backup directory for the latest backup file of localstore.x.x.x.mdb and make a copy of it.
HP Pavilion DV6
- Josh Rayburn
Re: Hardware DB
Depends on the OS hence the first question.....
I don't know on 7, I am running XP. You can do a search to find the folder but on XP it's in a hidden folder (application data).
My backup software does not backup hidden folders or files, so I was outta luck.
The installer is supposed to trigger an automatic backup of these files, into that localstore/backup directory.
Perhaps Ryan can relist the directories for each OS?
For anyone else reading: Please check your backup files to be sure your localstore files are backed up before installing!!
- Ryan Callahan
Re: Hardware DB
Bryan,
For Windows 7, the folder in question is
C:\ProgramData\Thermwood\eCabinet Systems\localstore
Hope this helps.
Hope this helps.
Ryan Callahan
Thermwood
Thermwood
