Request: Looking for Slow Cabinets to Regen in V6
Rick Deskins
Company Name: Thermwood
Post by Rick Deskins »
Anybody have any cabinets that are painfully slow to regen? Please Post zip file of cab and state the general amount of time it takes on your pc to regen.
Rick
Rick Deskins
Kenneth Rychlik
Re: Request: Looking for Slow Cabinets to Regen in V6
Post by Kenneth Rychlik »
This one takes 18 seconds to change from 18 inch to 26 inch width. It seems kind of painfull to me. lol This is a stock download from the frammed library. It has 4 dovetail drawers in it.
My pc is a few years old, but ran V5 pretty good. I was just using the downloaded library to do a "quick" design layout, but it wasn't quick at all. I am going to need to go back and delete all the drawers so it won't take so long for design work.
I hope this info is of some use for you.
Kenneth
001F Base_4 Drawer Stack.hsf
(2.15 MiB) Downloaded 303 times
Nat Wheatley
Post by Nat Wheatley »
Not painfully slow, but far too slow for what it is.
3mm_Base_Std_Pair.hsf
(1.42 MiB) Downloaded 340 times
Kenneth Rychlik
Rick in that same library download the base corner units that have a lazy susan in them take over 30 seconds to load or regen.
Take out the lazy susan and it loads in just a few seconds.
Kenneth
001F Base_90 Corner.hsf
(1 MiB) Downloaded 318 times
Kenneth Rychlik
I tried resizing even withought the LS and it still takes 25 seconds the regen.
Kenneth
Rick Deskins
Kenneth Rychlik wrote:Rick in that same library download the base corner units that have a lazy susan in them take over 30 seconds to load or regen.
Kenneth
Just FYI, I noticed that you used part editor cuts on the back parts to get a non mitered center back look. You can now do this with an option in Contruction Settings. If you go to Corner Settings and uncheck Miter Center Back. You will still have to cut down the left and right back with part editor cuts.
Rick Deskins
Kenneth Rychlik
Rick, I didn't modify that cabinet at all. That is the way it came from the thermwood free downloaded library. I didn't know there were PE cuts on it though.
If you REALLY want a slow one, take the island with the dovetail drawers in it from the stained face frame library. That one should lock up your system.
I am just working them up for layout 3d work. I have other libraries I am using for my cutting needs.
Thanks for the info.
Kenneth
