Non-Manifold Body
JohnLashuay
Non-Manifold Body
Post by JohnLashuay »
Hi Guys!
I am trying to cut a part using a closed contour and the response that I get is: "cannot apply the selected changes: the resulting part would have a non-manifold body."
What does this mean?
http://www.rylexonline.com
Thermwood CS 43
Brad McIntosh
Company Name: CNC Automation
Re: Non-Manifold Body
Post by Brad McIntosh »
I am guessing, but sounds like the operation would result in two separate "bodies" in the same "part".
Sounds to me that you are actually trying to change the overall shape of the part. This can be done in two ways (that I can think of):
1) Cut AWAY sections of the part.
2) Create a closed boundary that is then used to redefine the outline of the part.
In both instances you have to make sure that what you are doing will not result two or more unconnected pieces remaining in the "part" space.
Brad McIntosh
CNC Automation
Twitter: @bmcncautomation
JohnLashuay
Thanks Brad!
I made a dxf outline and it must have created two parts in the cut. I'll look at the part a little closer.
Thank you!
-John
Thermwood CS 43
