Parasolid Boolean Subtraction Failure - again
Post by Donald Thomson »
When trying to add a Conestoga CRP-20 or CRP-30 with the following settings I get the dreaded error in the title.
Standard Hickory material
Nutmeg 40sheen color
FP Profile
Alternate Source pricing - Cost/Sq Ft set to 30.00
Add a left hinge door and I get that error where it's saying "Parasolid Boolean Subtraction Failure while coping door bottom rail" :? :?
I get the exact same results when I try to add a Conestoga CRP-30 door.
Is there something wrong with this cabinet? Other cabinets take the CRP-20 or CRP-30 just fine.
CRP-20 and CRP-30 door problems.jpg (12 KiB) Viewed 5337 times
CRP-20 and CRP-30 door problems.hsf
(508.02 KiB) Downloaded 322 times
Scott G Vaal
Re: Parasolid Boolean Subtraction Failure - again
Post by Scott G Vaal »
Donald,
We have this listed and will be looking into it. For now, you will need to choose another profile such as the J-2 PROFILE. The issue seems to be related to the size of the door for some reason. A 16" x 24" door will create fine with the FP PROFILE, but the height/width combination around the size you are wanting (on your cab) is having the problem.
Thank you Scott.
I did notice that if I choose a different Conestoga door, other then the CRP-20/30, it works just fine with this cabinet. On another cabinet in this job, that has the same dimensions as the one having problems, the CRP-20/30 doors worked fine. There must be something about this cabinet and the CRP-20/30 that the parasolid boolean subtraction routine doesn't like. :roll:
Not sure what it could be....
Scott G Vaal
Donald,
Are you sure you are using the same profile etc. with the CRP-20/30 on the other cabinet?? I did not even use your cabinet for my test for the programmers. I simply loaded a display door into the cab/assm editor at the size that would get added to your cabinet (17" X 29.25") and it reproduces the issue. If you have a cabinet that will allow you to create the exact same door size using the CRP-20 with FP Profile, please get it to me so I can examine it.
Scott,
I've attached the cabinet that has a CRP-20/30 door on it.
CRP-20 door works.hsf
(644.02 KiB) Downloaded 333 times
Scott G Vaal
Donald,
The door is not the same size. The cabinet that works has a 1/2" narrower top rail making the door 1/2" taller (29.75" tall compared to 29.25" on the cab that fails). This puts it into a combination that works. The issue definitely looks to be size related. We will look into it. Thanks for your help.
You're right Scott.
I changed the top rail from 2" to 1.5" and it took the CRP-20 door just fine. Interesting that with a 2" top rail it won't take a CRP-20/30 door but other doors are fine.
