Create Part From Closed Contour
Georgi Baltov
Post by Georgi Baltov »
Hi Guys,
if it's not a big problem can you test the dxf that I have attached and see if you can create a part in any material. I can create a pocket from the part but can't cut out the part itself. It's getting kind of frustrating.
Let me know what you find. Thank you
WALL TRIM - POCKET INSERT.zip
(5.19 KiB) Downloaded 307 times
Georgi Baltov
Re: Create Part From Closed Contour
Never mind. It seems there was something wrong with the file because I imported it from Mastercam. Sensitive eCabinets. I redrew it in Autocad and it worked.
Thank you.
