Rabbeting
MarcoKnjaschewitsch
Rabbeting
So my newest Delema...Random cabinets that have been changed in batch show no tenons at the CNC. Is someone else having this problem?? First i had thickness issues with tenons on drawers which is now gone with build 4...but now this
last 2 batches i did looked clean...but wtf!!
- Scott G Vaal
Re: Rabbeting
Marco,
We will need to know more info to help you here. Can you post the job that had the issue? Also, we may need an export from Control Nesting at the machine. If you have not done this before: Load Control nesting, Load the job you are experiencing trouble with, Perform a nest, Then press the Export button on the main Control nest screen. This will create a .cab file that you can send to us.
