Converting segment to arcs
Ray Jorgensen
Post by Ray Jorgensen »
Does anyone have a solution for converting the segments in a dxf file to arcs that will work in the shapmanager? Hopefully this is clear!!
Company Name: Halls Edge Inc
Re: Converting segment to arcs
Post by Josh Rayburn »
I use BobCad, which has a feature called "create splines" and you can choose to "use arcs" as an option. This will accomplish the task, but I don't know what CAD program you are using. If necessary you can send me what you have and I'll see what I can do with it.
Ray Jorgensen
Thanks Josh, Here they are attached. I'm also going to do a search on Bob cad.
Crown2 scaled.zip
(11.51 KiB) Downloaded 465 times
Brad McIntosh
Company Name: CNC Automation
Post by Brad McIntosh »
Ray,
Mastercam Design LT also has the ability to "convert" any parametric splines into tangential lines and arcs. Should run you less than $300 USD. Design LT does not have any CAM functionality, but it is fine for the creation/modification of layered DXF files. If you do later move up to the full-fledged Mastercam Router CAD/CAM system, you should then already be fairly proficient in the CAD side of product.
I used Mastercam to "break" the splines in your "Crown" geometries into tangential lines and arcs. (See attached)
CROWNs SCALED (ARCS.LINES).zip
(21.81 KiB) Downloaded 476 times
Brad McIntosh
CNC Automation
Twitter: @bmcncautomation
Ray Jorgensen
Thanks Brad, I'll have to look into that.
Brad McIntosh
I forgot to point out that Mastercam Design LT (lite) is a product that Thermwood should be able to supply you. Contact Brent East at Thermwood.
Brad McIntosh
CNC Automation
Hi Ray,
Hope this is what you were looking for. Sorry for the delay.
Crown1 scaled.zip
(8.37 KiB) Downloaded 479 times
