Corner Hutch and shelf
Ken Zey
Company Name: Digital Millwork
Post by Ken Zey »
I'm still working my way thru ecabs tutorials, though have cut several cabinets using the basics.
Right now I need to make a triangular corner shelf and hutch and looking for suggestions as it seems to be beyond what I've learned so far. It will have a rustic face frame on the front, but just need to be able to cut the carcass pieces.
I've created the attached by starting with a upper corner cabinet then setting the sides to .1" wide and gives me a pretty close approximation of what I'm looking for, but get an error writing the .twd file.
Is there another way I should construct this type of corner shelf?
Gotta find some more tutorial time!
Snap1 [800x600].jpg (39.07 KiB) Viewed 8036 times
40corner.zip
(184.39 KiB) Downloaded 742 times
Ken Zey
Re: Corner Hutch and shelf
Post by Ken Zey »
With a little more testing, it seems the corner cabinet is not the problem. I'm getting a 8009000b CryptAquireContext error when I try to write a .twd file for any cabinet including those that have worked in the past or std cabinets. These are first jobs I've tried since upgrading to 6.4
Ken,
I don't know what the error is at the TWD file but for your cabinet you can use a corner cabinet and remove the ends and add negative insets to the top deck and shelves to make them work.
Ken,
I have attached the cabinet below if you want to see if it will work for you.
angle test.zip
(233.3 KiB) Downloaded 753 times
Ken,
Here is an upper angle. You may need to add a negative inset to the left and right backs to make your construction and doors work the way you want them.
upper_angle.hsf
(282.02 KiB) Downloaded 687 times
Ken Zey
Post by Ken Zey »
Thanks Kerry. I'll play around with it as soon as I get back in shop.
Still having the error, I'll call thermwood in a couple days when I get done with an install.
Thanks again for the help!
Ken Zey
Post by Ken Zey »
Thank Kerry!
Had time to play with your method today and got just what I needed.
Thanks again!
