load job
nest
look at drawer box parts in nest (screen shot of what I'm getting is attached)
I did not see this result nesting the job a few minutes ago, so the last thing i did was to replace the drawer boxes with drawer fronts in the room
i chose a new dbx, edgebanded it, did a rebuild, saved it, then clicked 'set default'
nested again, this is what i got - bug?
I will get it resolved for cnc but this might be worth a look...?
dbx bug?
- Josh Rayburn
dbx bug?
- Attachments
- dbx parts 100710.zip
- (4.48 MiB) Downloaded 271 times
- Josh Rayburn
Re: dbx bug?
ok, so after that, go back to the room
select all cabinets
adj features - change dbx with dwf again
message: cannot change drawer boxes because there are none
the dbx part bodies are all missing
take a cabinet with dbx's to the CE (i took a 3 drawer base, one on the 'island' on the lower right of the screen)
check for part bodies - 54
remove part editor cuts from entire cabinet
message: 'drawer box width is 0 - the drawer box will now be removed from the cabinet'
now they're gone
go to door / dwf editor
remove drawers
replace drawers again
check for bodies - 64
I've also attached the "offending" drawer box file, assuming that's the culprit
select all cabinets
now they're gone
remove drawers
- Attachments
- p725 w p725 bot PFM p5binset.zip
- (30.26 KiB) Downloaded 251 times
- Josh Rayburn
Re: dbx bug?
ok, now that i've taken each cabinet to the CE and deleted the drawers, then replaced them with a different drawer box file:
nest job
see message attached
apparently i was overconfident in getting this to work so now i need help
what else can i do?
nest job
what else can i do?
- Attachments
- error dbx 100710.zip
- (10.33 KiB) Downloaded 266 times
- Scott G Vaal
Re: dbx bug?
I talked with Josh on the phone about this and together we have reproduced it. I will investigate further and let everyone know the details when I narrow down the exact cause. Thanks Josh...
