Gary Puckett
Posts: 1324 Joined: Mon, May 19 2008, 1:39PM
Company Name: The Woodworkery
Post
by Gary Puckett » Thu, Oct 07 2010, 10:02PM
I need to show a raised panel bar front, so I took a cabinet and eliminated all the parts except the face frame. When I go to put it in the room the face frame will not show up. But if you put the mouse arrow where it should be it says it's there.
Any Ideas
Posts: 4764 Joined: Mon, May 09 2005, 7:33PM
Post
by Kerry Fullington » Fri, Oct 08 2010, 6:32AM
Gary,
Post the job.
Gary Puckett
Post
by Gary Puckett » Fri, Oct 08 2010, 7:07AM
Kerry,
I tried 3 times to post the job. If you want I can try to email it to you.
If I save it as an assembly it will show up.
Gary Puckett
Post
by Gary Puckett » Fri, Oct 08 2010, 7:26AM
It is loading as we speak, don't make fun of all the lights
I tend to get a little carried away.
Post
by Kerry Fullington » Fri, Oct 08 2010, 7:36AM
Gary,
I haven't seen your job yet but your last statement tells me what it is. Take out some of the lights. George Davidson had a similar problem and it was because too many lights.
Remove lights till your face frame appears.
Post
by Kerry Fullington » Fri, Oct 08 2010, 10:53AM
Gary,
I never received your email. Did removing some of the lights fix the problem?
Gary Puckett
Post
by Gary Puckett » Fri, Oct 08 2010, 12:34PM
Kerry,
I will try and send it again. I removed all the lights and it still did not show up as a cabinet.
Post
by Kerry Fullington » Fri, Oct 08 2010, 1:29PM
Gary,
Have you tried re-starting windows and eCabinets. Everything shows up for me in custom layout and in presentation view.
Gary Puckett
Post
by Gary Puckett » Fri, Oct 08 2010, 2:33PM
Kerry,
I had to save them as an assembly, thats why they are showing up.They will not show up if you save it as a cabinet.
Post
by Kerry Fullington » Sat, Oct 09 2010, 9:06AM
Gary,
I see what you mean. I would build another cabinet from scratch. It appears that something must have been corrupted in your cabinet file. I have some panel cabinets done the same way and don't have a problem.
It could be that the cabinet you built the face frame from is corrupt.
Gary Puckett
Post
by Gary Puckett » Sat, Oct 09 2010, 10:23AM
Kerry,
I tried it again with a new cabinet and still no show. I then made a new job with a new wall, tried it and still no show.
I am trying to cover the complete long wall so my cabinet is over 120" and 42 " high. Do you think that is the problem?
Post
by Kerry Fullington » Sat, Oct 09 2010, 11:06AM
Gary,
Try the attached cabinet. If it works you will have to change to the door you wee using for the panel.
wainscot.hsf
(166.02 KiB) Downloaded 768 times
Posts: 1585 Joined: Tue, May 17 2005, 1:16PM
Post
by George Davidson » Sat, Oct 09 2010, 12:27PM
I tried a tall framed cab, with just the face frame Deep at 24",12",3/4" and each one in custom layout. Each one shut down my e-Cabinet program
I have to go today is our grandson's birthday the big 3.
3 weeks ago my son had to give a way some of Michael's toys so they would have room for his new toys?
Gary Puckett
Post
by Gary Puckett » Sat, Oct 09 2010, 4:06PM
Kerry,
This is what I get when I open your hsf file
