Corner cabinet inset doors
Jon Dieterlen
Post by Jon Dieterlen »
I have a framed angle front corner cabinet that will not size the door properly when the door inset is set to 3/4". The overlap changes to gap, as it should in the door editor, but when it returns to the main area, the door changes sizes, and the gap is returned to overlap.
I have the right and left stile set to a negative 1/2" scribe so the top and bottom rails are sized properly. If I change the scribe to 0, the inset and gap settings work correctly.
Is this a known issue?
Thanks, Jon
Angle front corner.hsf
(494.02 KiB) Downloaded 319 times
Scott G Vaal
Re: Corner cabinet inset doors
Post by Scott G Vaal »
Jon,
No, this was not a known issue. I have it documented now and it should be resolved for the next release. Thanks for the report.
