Box seed cabinet
Will Williamson
Box seed cabinet
Post by Will Williamson »
Does any one have a seed cabinet that is a box enclosed on all sides? If not what is the best way to accomplish this?
Will
http://www.willmade.com
Company Name: Halls Edge Inc
Re: Box seed cabinet
Post by Josh Rayburn »
Hi Will,
You can make this by putting a face frame on the front of a standard cabinet with or without a toekick. Use a "left stile" or "right stile", or you can use a "top rail" or "bottom rail" - the problem is that if you change the size then you have to change the width of that face frame part manually.
Will,
Just use a stretcher for your front.
Lock your positions and it will re-size with the box.
Will Williamson
Almost been four years since setting up my machine and I have only cut 2 or 3 cabinets so just now starting to learn Ecabinets
Will
Will,
Here is the cabinet if you want to look at it. This is all butt construction but you can change it to any joinery you like.
box.hsf
(168.02 KiB) Downloaded 315 times
