CNC Cutting Out of Square
				Darrel Wells
 - Company Name: Western Woodworking
I have a 3-Axis Thermwood Model 45, and it seems to be cutting out of square, the parts cutting like a parallelogram.  What would cause this, and what's the solution to correct this?
						- Brad McIntosh
Re: CNC Cutting Out of Square
Sounds like your gantry could be out of square.  Have you had any crashes lately that could have knocked one side/leg?
You may want to contact Thermwood's technical services to see how to go about checking the gantry for squareness.
Darrel,
You can check bridge squareness by placing a precision square on the table, aligning base end of square with the X axis using an indicator, once aligned with X axis, then you will use the indicator mounted to tooling plate and run it along the Y axis of square to check amt. of error. The larger the square the better. There should also be squareness numbers marked somewhere on the front edge of machine table, typically underneath front endge. Lastly, you could also unbelt the base drive screw opposite the HOME switch side, HOME the machine, then place belt back on drive to possibly get squareness back.
If you have further questions, you can email: service@thermwood.com
Thanks!
Thanks!
