Drawers Losing PE Cuts on Cabinet Resize
Nat Wheatley
-Reduce width of attached cabinet by several inches. PE cuts disappear.
- Attachments
- 3mm_Base_Std_Pair.hsf
- (1.44 MiB) Downloaded 326 times
- Scott G Vaal
Re: Drawers Losing PE Cuts on Cabinet Resize
Nat,
The drawer box bottom and back does not have any constraints set. This is why the cuts are going away when you reduce the width by several inches. Now, with that said, I see that your default box seems to have constraints set. So, I went and removed the box and added it back in and it then seems to be OK. Any Ideas as to the steps you took to get it in this state?? Or is there more to the story than what I am seeing here?
Nat Wheatley
Thanks Scott. The constraints were there at one point, I'm not sure at what point they disappeared.
Nat
Nat
