crazy dimensions in assembly
Leo Graywacz
Post by Leo Graywacz »
I have a complex assembly that took a while for me to put together. Now that I need to do some final adjustments it is acting wonky.
I need to make the left door opening of the left cabinet of the assembly 1/16" larger but when I bring it into the FF editor it gives me some crazy opening measurements.
The height is -200"
the Width is 282 27/32"
Here is the assembly file.
Sink wall upper.jpg (12.61 KiB) Viewed 5446 times
Sink wall upper.esa
(2.81 MiB) Downloaded 488 times
Dell Precision 7710
NVIDIA Quadro M3000M
512 GB PCIe NVMe - M.2 SSD
Win 7 Pro 64-bit
http://lrgwood.com
Dave Zimmerman
Re: crazy dimensions in assembly
Post by Dave Zimmerman »
I've been having the same trouble but if you click on the opening and set it to what you want it straightens out or at least it has for me.
Leo Graywacz
I found a couple of issues with various parts not wanting to play well with each other.
On the right cabinet, the left side couldn't be edited, kept getting errors.
On the left cabinet, I deleted the top and reinserted it and that seemed to get rid of that cabinets problem.
Now I have an issue that I can't get it to put a dado on the backside of the right and left sides of the left and right cabinets. That one is still unsolved.
Dell Precision 7710
Win 7 Pro 64-bit
http://lrgwood.com
Leo,
Have you restarted Windows and eCabinets.
I am not seeing the problems with your assembly.
Leo Graywacz
restarted eCabs, not windows. Guess I should try that, huh. :wall:
Dell Precision 7710
Win 7 Pro 64-bit
http://lrgwood.com
Scott G Vaal
Post by Scott G Vaal »
Leo,
Interesting situation. It took me a few minutes, but I have finally reproduced what you are seeing. If you take an assembly of cabinets (that have face frames) from the custom layout area to the cabinet editor, you will get these goofy looking FF section sizes. It appears to only do this when taken from the CL, loading the assembly directly into the cab/assm editor or from the batch will not present this anomaly. I will get this listed and fixed. For now, If you need to modify an assembly cabinet from the custom layout, you can regen the cabinet (select Construction Settings and then select OK) first and then go into the face frame editor and the section dimensions will show correctly.
