Trying to add some hole pattern to the side of a draw box and running into a bit of a problem, i have made a hole pattern and just cant work out how to get it from the hole pattern folder to the right side of the draw box i could put them in manually but thought you could do it quicker if you made a hole pattern
Jason,
Does your hole pattern have a positive depth for the holes being bored into the side of the drawer box and negative depth for the holes in the case side? I have not tried it yet, but I believe this was how it was originally intended to work. I'll have to give it a go today and see if it works.
