tooling for hinge holes?
Jim Carter
Company Name: Jim Carter Corp.
Post by Jim Carter »
I am getting an error message when I try to nest these parts.
"you need to set a tool for Pocketin or Drilling in tooling for drill operation 53......
this error message repeats itself 16 times for for different parts. I assume it is referring to the 16 8mm holes the hinges.
I cut several doors two days ago with out any problems, I have changed tooling and settings every thing I can think of. I was trying to use a .25 tool to interpolate to the 8mm hole needed.
the other thing with this nest is that when I look at the g code it does not appear that it is cutting out the center of the glass door Z never drops down to the table accept for the out line cuts.
any ideas, solutions?
12-3-15 Gosha doors.esj
(1.69 MiB) Downloaded 425 times
jim@jimcartercorp.com
973-224-0221
Ringwood, New Jersey
Jim Carter
Re: tooling for hinge holes?
atttached is the export file
thanks
Jim
I do not know why I can not upload the export file. ?
973-224-0221
Company Name: Halls Edge Inc
Post by Josh Rayburn »
Jim, zip the export file then try to attach.
Jim Carter
thanks Josh
ControlNest5-68.zip
(89.44 KiB) Downloaded 415 times
973-224-0221
Joe Harger
Post by Joe Harger »
Jim, it looks like your material is set up for Group 1...under that group it looks like there is no 1/4" tool set up (or any tool small enough set up to interpolate) to interpolate those holes...Was getting error until I added a 1/4" tool and selected interpolate....Let me know what you find
Joe Harger
Software Support
Thermwood Corporation
Jim Carter
Joe
that is what it is.
I don't normally use groups and keep the ignor groups boxed checked.
:wall:
973-224-0221
