Help With Constraints
Scott Marshburn
Post by Scott Marshburn »
Would someone be kind enough to look at this door and help me with the constraints. I am able to constrain the arcs to resize like I wish when the width changes but now the height of the door won't resize at all. Thanks for any help.
Scott Marshburn
Re: Help With Constraints
Sorry The file did no attach
SingleLight.hsf
(86.02 KiB) Downloaded 467 times
Scott,
Remove the two constraints in this picture and see if it still doesn't work properly.
Scott,
I think there might be a bug in this. I can adjust the height of your original door if I use small increments.
example - I can adjust the height from your 21" to 23" then to 26" then 30" and it works but if I try to go from the 21" directly to 30" it does not work.
Scott Marshburn
Thanks Kerry for your response but I may have to start from scratch on this one. Try taking it from 14 1/2W to 32W That won't work. Maybe some one out there has done this type of door before? I sure could use some help on this.
Arch12to13inNewConstraints.hsf
(316.02 KiB) Downloaded 442 times
