Creating custom doors
Alex Bowler
Company Name: cutshop
Country: NEW ZEALAND
Post by Alex Bowler »
Hi
I there any way to create custom door and apply them to a kitchen. I would like to create a door with 3mm deep v groves about 100m apart.
Re: Creating custom doors
Hi Alex
It could be done this way.
I'm don't know if its the best way
I constrained the grooves in the constraint manager.
For every size unit you would need about 100 mm leeway. So a 410mm unit has 3 grooves. (Have to think cup holes, about 55mm from edge)
The formula i used to constrain the edge was W/2 -150.
Where 150 = the width of the grooves /2
I didn't tidy up the cut paths.
Vdoor.hsf
(976.02 KiB) Downloaded 1065 times
Alex Bowler
Hi
Thanks for that does did you use part editor and constraint manager the grooves?
Hi Alex
Yes I did. You can download the vdoor.hsf and put it in your cabinets directory. It might give you an idea on how to do it. You also need to make a cutter or .tol file for the v groove.
If you really want to learn how to do it properly and haven't spent much time in those areas I would join up to the Ecabs training videos for a month or so.
Dennis makes it all pretty simple,There are a few processes and he breaks them down into 5, 10 15 or 20 minute tutorials.
If you have a machine it would be essential to view them to get the most out of it.
Hope this helps
Mark
KyleHepp
Post by KyleHepp »
I just saw some options in the Conestoga doors that look quite familiar to what you're after. might be worth a look...
I was hoping to find some direction on how to layout passage and entry doors in ecabs. I've tried stretching out a couple cabinet doors, and they just don't turn out right
Al dedenus
Post by Al dedenus »
For entry doors I take a cabinet,remove everything but the face frame and resize it accordingly for my door frame.
Depending on the type of panels, I use either the door editor or display panels.
