Roughing to skin
Stuart Douglas
Roughing to skin
Post by Stuart Douglas »
Has anyone been able to set CN to rough to the skin, then ONLY cut through the skin on the final finish pass? I can't seem to get the setting right for this. My current setup will run the roughing steps to the skin, then cut through the skin with the roughing bit, freeing the work from the off-fall, then the final pass will sometimes cause the work to move (mostly long narrow bits) and ruining the piece. I'm sure I'm missing one critical setting somewhere that will enable this, but for the life of me I can't seem to get it to do this. TIA. :oops:
_____________
NVME SSM2HD 1TB NTFS
Stuart Douglas
Re: Roughing to skin
Bump. Anyone successfully doing this already? Maybe you could send me your CN settings to peek at. :beer:
_____________
Clint Buechlein
Company Name: Thermwood Corp
Post by Clint Buechlein »
Stuart,
There isn't a setting for what you are wanting to do. I'll put it in as a feature request for the software engineers.
Clint Buechlein
Stuart,
This feature has been added in Control Nesting version 7.06 released today. There is a check box at the bottom of Roughing for this feature. With that box checked, the machine should cut down to the double pass skin leaving the cleanup on the part with the roughing tool, then cut the double pass skin and cleanup with the outline tool.
Stuart Douglas
Awesome! I cant wait to try it out :beer:
_____________
