Take an eCabS job to CN. Sort for one material only. Add a piece of off-fall material manually. Nest true shape x or y and it pops errors "unable to nest..." as if the added off-fall is the only sheet available, even though the material catalog contains viable standard materials with appropriate sizes. I can nest using rectangular optimization, and it will add the standard sized sheets as necessary from the material catalog.
_____________
NVME SSM2HD 1TB NTFS
Your Default group has Only Use Added/Off-Fall Sheets When Available checked. This group is being used for the 3/4 Melamine Frosty white material in the job your export contained. When that option is checked, Control Nesting will only nest on added or off-fall sheets.
There is still an issue in consistency to Rectangular Optimization that the software engineer will need to look at so I'll get that reported. This is such a rarely used setting I'm not surprised no one has run into it for rectangular nesting.
