6 in Fluted column
Greg Smith
6 in Fluted column
Post by Greg Smith »
In case anyone has a need for this.
6\" square to start, .25 offset and -6.25\" plunge
flip and repeat for full column
fluted column.jpg (35.88 KiB) Viewed 75007 times
6in fluted column.tol
(11.15 KiB) Downloaded 2563 times
Al dedenus
Country: NEW ZEALAND
Re: 6 in Fluted column
Post by Al dedenus »
How do you flip it to do the other side???? :wall:
Greg Smith
Its been a while so I had to go and try it and see what I did. The trick is where you click on the part when making the profile cut. Click on the lower left side for the first cut and then the upper part of the right side for the second cut, and it should work for you. Where you click is the start of the cut so you can change the direction of travel by changing the start. Hope it helps.
Intel Core i5 3.47GHz, 8 gig RAM, Quadro FX 1800, Win 7 x64
Al dedenus
Thanks Greg worked a treat :D
