G901 Settings Off
Zach Froble
G901 Settings Off
Post by Zach Froble »
I adjusted my 901 settings to run some custom mouldings that I had to fixture. My problem now is that even though I changed them back they are not correct. I checked them several times to make sure it took the changes back to my normal.
Zach
Lyndan Designs
Machining and CAD Services
Dave Burtchell
Post by Dave Burtchell »
Zack,
Don't forget to drop down to the last line and hit the start button, or is it the block step + button? Anyway, if you don't do this, your changes won't be saved. Just a thought.
Dave
Zach Froble
I thought I had already done that, but that evening I went back and tried it again and everything seems to be working fine now. Thanks for the reply though.
Zach
Lyndan Designs
